show mvrp tag
show mvrp tag vlan_tag {ports {port_list}}
Description
Shows the port specific applicant and registrar states and the configured control values for all MVRP enabled ports.
Syntax Description
mvrp Multiple VLAN Registration Protocol.
tag The 802.1Q VLAN ID.
vlan_tag VLAN ID ranging from 1 to 4094 (default is 2).
port_list Port list separated by comma or "-".
Default
N/A.
Usage Guidelines
Use this command to show the port specific applicant and registrar states and the configured control values for all MVRP enabled ports. The registrar control value is derived as follows:
# show mvrp tag 2
Port    Applicant     Applicant     Registrar    Registrar
        State         Control       State        Control
            9         VN            On            MT           Normal
            11        QA            On            IN            Normal
            13        QA            On            IN            Normal
Applicant States:
        AA     : Anxious active,        AN       : Anxious new,
        AO     : Anxious observer,      AP       : Anxious passive,
        LA     : Leaving active,        LO       : Leaving observer,
        QA     : Quiet active,          QO       : Quiet observer,
        QP     : Quiet passive,         VN       : Very anxious new,
        VO     : Very anxious observer, VP       : Very anxious passive
Registrar States:
        IN     : In – Registered,       LV        : Leaving - Timing out,
        MT     : Empty - Not Registered
Applicant Control:
        On     : Transmit On,          Off       : Transmit Off
Registrant Control:
        Fixed  : Statically added,     Forbidden : Forbidden VLAN,
        Normal : Dynamically added
This command was first available in ExtremeXOS 15.3.
Platform Availability
